ATS
Hotavick
I have an ATS connected to the reserve to a solar system and the main power supply from the grid, but from one moment to the next it stops making the transfer to the reserve or in other words to the solar system, but it does do it from the reserve to the main source, could you help me find out what the problem is? Regards
    96,9 KB · Visitas: 2
2j_
you have two options:
-repair if you have knowledge look it up on youtube
-buy a new one
Hotavick
Thanks friend for answering, I already solved the problem, I checked it and I had a contact stuck in the relay, it was welded, it is now working well, I have to have a backup for when something like this happens, greetings
Vendrá de serie con el recloser, pero ese tipo de contacto no es idóneo para esa aplicación, donde se necesita que sea AC-5A. Si fuera de esta característica no se podría desmontar así por la de buenas
